RVCFIRE said:
**Remeber EDCAS trunking system have to start at the Bank Channel 01
If you start it at 00 it doesn't work. :wink:
This is true, if the LCN order starts at channel 1. Not all EDACS systems/sites start with 1. Take a look at the
RACOM system for an example. That system also contains examples of sites that can be placed in the same bank and still function correctly, take a look at Victor and Sioux Falls, SD or Sioux Falls and Pierre, SD. In each instance since Sioux Falls is in channels 1 through 7 and the others start higher (and hence must be placed in those slots to work) you could put both sites in the same bank and it would work.
RVCFIRE is 100% correct in that there are never any LCN 0 channels. (The same goes for LTR, although the Pro-95 won't track LTR systems.)
