Pro 96 accessories needed
wmbio
Cumberland, Md
Hi Folks,
I picked up a used pro-96 at a yard sale in Washington DC today.
I am in need of the following if any memeber can help?
1. The standard stock, antenna that comes packaged with the radio, ( HAS A GREAT 800 MHZ STUB ON NOW )
2. The yellow rechargable battery pack.
3. The instruction book.
If you can't help can you provide me with the part numbers for these items from RS?
Thank you,
73's WMBIO
scnnr
Manitoba, Canada
wmbio said:
Hi Folks,
Thank you,
73's WMBIO
You can download the manual here http://support.radioshack.com/support_electronics/71295.htm
This link for quick set up reference
http://wiki.radioreference.com/index.php/Programming_Shortcut_pro-2096
Also Try the Radio Shack site for various antennas. I would get the 800 MHz antenna as I use it exclusively.
http://www.radioshack.com/product/index.jsp?productId=2036238&cp=2032052.2032072&allCount=18&fbn=Type%2FDigital+trunking&f=PAD%2FProduct+Type%2FDigital+trunking&fbc=1&parentPage=family
Enjoy the scanner.
Cat.No. 12228805 HOLDER ASSY FOR RECHG. BT NP Part # HB90252
wmbio
Cumberland, Md
pro 96 accessories
Thanks, The unit was completely programmed when I turned it on. I do not live in the DC area just visiting, but could not resist the bargin!
I have a RS 800 mhz antenna, in fact I have 2. I need the stock antenna or the part number for the 96 as I have some low, high and uhf stuff I want to monitor in Western Md.
Thanks Guys again.
Wmbio
Lochtsa
Radio DShack part number-Antenna
Deluxe Antenna for Handheld Scanner
Model: 20-034 | Catalog #: 20-034
This deluxe antenna for handheld scanners is a great replacement for a lost antenna
