pro-96 and a vhf apco 25 system (ontario, can)
dave540
hornett
I'm having some programming problems... ive setup the control channel and its in MO mode, the base freq and offset are set (141.015 and 15) but when any activity is detected, the voice channel shows something in the 137mhz range...which isnt correct... any idea what im doing wrong?
also, the step size is set to 25khz
dave540
hornett
offset is at 380 and step is 15....still geting VC in the 137mhz range, which isn't a valid frequency for this system...they are all 141/142mhz range
help!!
dave540
hornett
additional info
i am seeing the correct id's for the system when it switches to the voice channels (i have a 250d as well, its working fine) the voice channels its switching to are way off
firmware is 1.2
dsp is 1.1
did the dsp test as mentioned in the manual and it shows 'failure' but im not sure if that is being performed right? Has anyone else run that test? what is the expected result?
also, loaded an edac's system, its not switching to the right voice channels either.. and i have the LCN's correctly entered (as verifed by the 250d)
is this thing toast or what? i just bought it today... !!!!
dave540
hornett
update
Edacs does work, i missed the info about starting lcn's at chan01 rather than 00...
ov1
Pro 96/OPP VHF settings
Dave,
Try this.... Manually stop on an active control channel. Press FUNC-Trunk,
Then FUNC-3...Make sure it is set to 'Table'.
Cheers,
Terry
kikito
North Pole, Alaska
Set the radio to use "Table" by using FUNC+3 option....
The test that shows "failure" is supposed to have a test set signal injected into it to work most likely....
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Next time try posting your question in the Canadian forum. We've got lots of people already monitoring this particular system with the Pro 96 and Uniden scanners.
There's a FAQ for setting up the Uniden scanner but nobody has come forth to write one for the Pro96 yet.
dave540
hornett
update
problem solved.!!!
it seems that you need to set the control channel mode to 'table' rather than normal for the ontario system with the pro-96
thanks to everyone for their assistance!
special thanks to the two members with the 'table' suggestion!
scnnr
Manitoba, Canada
Re: additional info
firmware is 1.2
dsp is 1.1
Dave I also noticed that your dsp is only 1.1 Is this correct or did you make a typo error. If you are running firmware 1.2 it should have come with the dsp version of 1.2. If not here is the file and instruvctions on how to upload it.
Randy
