Pro-96 Antenna Conector
ke5fgc
Tyler, TX
The BNC connector on my pro-96 has a loose connection on the board. Has anyone tried to resolder the BNC connector on? If so did it work?
-josh
unitcharlie
a Kentucky DB Admin...
far from Nonesuch, Ky...
Yes, carefully remove the box and it is a really quick fix.... while you are at it, if you can get a more solid BNC you might just change it now because it will wear out sooner than later...
