If you press and hold the backlight button to make it stay on as stated above, and you manually stop on a channel, then the scanner will go into battery save mode and turn the backlight off, when squelch is broken, the light will come back on for a time, then go back off.
You can only do this on a conventional channel in manual mode, it won't work with a trunked system.
