Pro-96 Cable
Hey, I have a Gateway 350S laptop. It does not have the correct Port for the standard Computer cable to go in, so I bought an adapter so it would plug into a USB port. When I plug it in the computer will not recognize it. I have tried it w/ ScanRec and Win96 & it says that its not connected. Will these programs not work in aa USB port or is it something else. Any help would be appreciated.
-Dylan
KG4KHQ
High Point NC
I also have a Gateway 350. What kind of adapter are you using? I'm using the Iogear serial to USB cable (came from Best Buy) and it works fine with Win96 for me.
Its called an Airlink 101, and it just goes from the scanner cable to the USB port.
KG4KHQ
High Point NC
That's what my cable does also. From what I have read, serial to USB cables can give unpredictable results, in fact my cable which works fine with Win96 will not work at all with the programing software that Im using for my Yaesu HT amateur radio. The only other thing that I can think of is going into Device Manager in Windows XP and make sure the cable is recognized and, if so, it should give the Comm Port that it is using, make sure that Comm Port matches the one you are using in Win96.
Yea, I just tried that and it still isnt working, thanks for your help though.
Al42
Long Island, NY, USA
Go to the manufacturer's site and download the latest driver. If that doesn't work return the converter and get the Keyspan, IOGear or Belkin.
Yea, my computer was saying the driver was out of date so that might be the problem. What website do I goto though?
Thanks for the help
-Dylan
