Pro-96 Crashed
Samuel
Prince William, Virginia
Pro-96 CRASHED
HOLY CRAP! I just tried turning on my Pro-96 and it is stuck at the DSP Loading Boot: F1.0 screen! Anybody seen this before? I can't believe it crapped out on me like this.
Yea , sometimes it gets stuck on that screen with mine. Usally If I just turn it off and back on againg it goes back to normal.
Sometimes it happens it the batteries are dead also.
I dont know why it does that.
Samuel
batteries arent dead and i tried turning it off and turning it on again and its still doing it. I tried resetting the radio and it did nothing....
loumaag
Silent Key - Aug 2014
Katy, TX
Sam, no need to appologize. That is why we lurk here anyway. :)
Sorry it is out of warranty. I seem to remember somebody commenting about this sometime in the past but couldn't find the post and hence can not remember what the solution was, but I don't think it took a repair. :?
Voyager
Re: Pro-96 CRASHED
I saw one do that. I recommended he return it for replacement. Try squeezing the sides near the front of the case, or try squeezing the front and rear cases in the middle.
Not sure what is causing it, but it could be a cold solder joint on some component.
Joe M.
loumaag
Katy, TX
Samuel said:
UPDATE: For furture reference the Service Center advised the PCB Board went bad. Cost for repair is 280.
:shock:
Ouch! :eek:
busaninja
Kansas City
Whoa, mine did that the other day 3 different times. Not good news, especially since I'm broke. Hopefully the OP is in a better financial situation than me.
Good luck OP
RyltnVFD
Over here.
Re: Pro-96 CRASHED
Mine had some major audio problems, the volume was almost non-existant, and you had to squeeze the thing to make it produce sound. I opened it up, and there was just a little plug with two prongs serving the sound output to speaker and earphone, and it wasn't plugged in all the way.
I just snapped it back together, and put the screws in, and it now works good as new.
xusmarine1979
Louisville, Ohio
Ya'll remember when I sold that damaged 96? The gentleman that bought it was able to exchange it for a brand new one. Go figure...
DaveIN
Founders Curmudgen
West Michigan
How did he do that? Take it to the local RadioShack and ask for another one?
