PRO-96 date codes?
D
DaveNF2G
Guest
I know I've seen a message about this somewhere, but I can't find it now.
What datecodes are known to have v1.3 firmware installed?
Herm
Wheeling, WV
I picked up a new Pro-96 yesterday that is all up to date. The code for my scanner is 06a04.
Herman
lndshrk
S.E. Salt Lake County
This gets interesting...
I just bought a 07A04 date code Pro-96 (on the box) yet it's
a v 1.2 CPU.
Any thoughts? I have a few :evil:
Jim
PS: This gets better.. the box says 07A04, but the RADIO says 01A04.
I'd love for someone to confirm my thoughts.
RDCat
N.W.
mine is also 01A04
in colorado
seems to work ok for analog 800 and DTRS systems
Voyager
a v 1.2 CPU.
Jim
I believe 06A04 is the first factory 1.3 version. The fact that your box says 07A04 doesn't matter. You have a July box with a January radio.
I'm pretty sure this is correct:
08A03 or later V1.1
01A04 or later V1.2
06A04 or later V1.3
Of course, any 'earlier' model could have been upgraded at Ft. Worth.
Joe M.
scanbc780
Usually Lurking
Maricopa/Yavapai Counties, Arizona
a v 1.2 CPU.
Jim
Heres my thought. Someone bought a 01A04 and it was 1.2 and they wanted a 1.3 so they went and bought a 1.3 (07A04) and returned the 1.2 in the new box. Now they have a 1.3 and you are stuck with a old 1.2 :? and a new box :shock:
D
DaveNF2G
Guest
Thanks, everyone. I expect to be able to buy one within the next couple of weeks and wanted to save myself some trouble. Now I know what to look for.
73 de Dave, NF2G
james32746
Lake Mary, FL
a v 1.2 CPU.
Jim
I ordered my PRO-96 from RadioShack.com in late July and both the box and scanner are
01A04
CPU-F1.2
DSP-U1.2 (the factory already put the DSP updates on the scanner)
VOC-F1.0
D
DaveNF2G
Guest
Apparently not. I just checked a unit in a local RS store that had the date code 06A04 (inside the radio - and BTW there are no date codes on the boxes at this store) 06A04 and the version was 1.1.
Voyager
Someone probably bought one, replaced the rear cover (with the S/N and date code) with their early V1.1 unit, and returned it as 'not wanting it'. In essence, they committed fraud and got an upgrade for free.
It is unthinkable that an 06A04 would have original firmware. The factory stopped making 1.1 in January, 04.
Joe M.
edweirdFL
Daytona Beach, FL
I just picked up my Pro-96 this month.
07A04
CPU-F1.3
DSP-F1.2
VOC-F1.0
Ed
<edited DSP to F1.2 from U1.2 on 12/20>
Voyager
07A04
CPU-F1.3
DSP-U1.2
VOC-F1.0
Ed
The DSP was an upgraded version??? I thought DSP 1.2 came out about the same time as CPU 1.2. I know DSP V1.2 came out at the end of January, 2004. I also thought it was factory installed around April, 04. (resulting in an F1.2 version)
Joe M.
Voyager
edweirdFL said:
As far as I know, mine was straight from the factory, no updates after manufacturing.
Ed
Well, the U in front of the 1.2 indicates it was an Upgrade. F = Factory.
Joe M.
edweirdFL
Daytona Beach, FL
Joe M.
Cool! I'm learning new stuff all the time. I made a mistake when typing it in, it should be an "F" and not a "U". My bad.
Ed
Voyager
edweirdFL said:
Joe M.
Ed
No, your GOOD! 8) :p
Joe M.
