tonya said:
Just bought a pro 96 on 04/27/05 so i'm still under the 30 day warrenty. on the display there is area lighter then the rest of the display it is about the size of the N when the radio shows scan up. has anyone else had this happen? i'm fairley sure i'm going to exchange this radio but would appreciate any imput
The 'spot' is caused by the light diffuser not being in its proper placement. That's the white piece of plastic that sits between the LCD and the logic board. If you're brave, you can fix it yourself, although it is a little tricky to get it lined up properly since the LCD is connected to the logic board. If you choose to try this, YOU DO SO AT YOUR OWN RISK. I've fixed several that had that problem.
If you're not completely comfortable in doing this, return your unit for another if you're in the 30 day period.
It's been reported as dirt of the diffuser and other issues, but the problem is the simple alignment of the diffuser - not dirt.
Joe M.
