Pro 96 Not decoding Digital Talkgroups San Diego
donrob36
Lakeside CA
Hi all,
A friend of mine brought me his Pro 96 to Troubleshoot. I did a reinitialization and put in some basic talkgroups both digital and analog. His DSP was 1.1, I was not able to get digital talkgroups to decipher so i upgraded the DSP to 1.2. still no digital talkgroups. Upgrade to 1.3, still no digital. Upgrade to 1.4 DSP still nothing
Have programmed all freqs and CC's only for RCS South Zone
Open and Closed modes yielded the same results.
Does anyone have any suggestions how to proceed ?? Before sending it to RS for help
TY Don
mikey60
Oakland County Michigan
If this is the Motorola Type II system, you would need to set it to use the Splinter bandplan due to it's proximity to Mexico.
Mike
donrob36
Lakeside CA
OK reverted to 1.1 DSP and Changed antenna to 800 mhz. Does pick up digital talkgroups but very broken. Have only CC's programmed thru Win96 as a splinter system from RR database. The clarity is the issue. Lots of broken signal compared to my Grecom 500 side by side Also im in Lakeside
rananthony04
Greater Los Angeles Area
Here's a shot in the dark.
There is a thread somewhere in the RR forums that explains how to adjust the VR4 dial on the circuit board of the Pro-96. It helped my decoding issues.
Also, what decode % is shown for the CC?
donrob36
Lakeside CA
Pro96 Fixed
TY all for your replies. Was able to Fix the decoding problem with a slight tweak to VR4. An 1/8 turn counterclockwise fixed it perfectly.
TY Again
Don
