lyle9076 said:
what is the 1.3 upgrade thank you
Here is the short version:
V1.1 is the original version.
V1.2 fixes the TG lockout (above CH 4-08 ) bug.
V1.3 fixes the 48xxx TG reception problem.
(47872, 47888, 47904, 47920, 47936, 47952, 47968, 47984,
48000, 48016, 48032, 48048, 48064, 48080, 48096, 48112)
Note that the 48xxx TG problem only affects ANALOG TGs, not digital.
That said, there seems to be a number of systems potentially affected.
There is a list here:
http://www.radioreference.com/modules.php?name=Forums&file=viewtopic&p=70005
Here is a little more info summarized:
Whether it is necessary to upgrade depends on whether you want to listen
to any of the affected TGs. Bug #1 is easily worked around (fill up TG
bank 4 first). If there are no TGs you want to listen to, odds are there
never will be. I decided it was better off for me to not lose my scanner
for 6 weeks for an upgrade I really didn't need - even though I do
travel to an area with an affected system. There aren't any TGs I can
live without as much as losing my 96 for 6 weeks (That's how long it was
running when I was still under warranty). It may be down to 2 weeks now
if you are really lucky, but I still prefer to not lose 2 weeks worth of
use over an upgrade I may never use.
The upgrade is free as long as your unit is under warranty, and is about $50 if it is not still under warranty. If you have to have the upgrade, but
can wait, you may be better off waiting until the end of your 1-year
warranty period just in case they come out with V1.4.
Joe M.
