firescannerbob
OK, this is going to take a while to explain, so bear with me...
One of the feeds I host on here uses a Pro-96 to feed a P25 9600 baud system. All the talk groups I scan for the feed are on the same radio system (same towers, etc), and the TG's I scan are a mix of city and county agencies. The feed is located where it can receive several towers with no problem (over 90%).
Periodically (and with out any ascertainable pattern), the scanner will just stop receiving a random TG. It may be the county fire dispatch TG, or the city fire dispatch TG, or a fireground TG, or whatever. After a while (again, no set pattern), it will start receiving the TG without any intervention from me.
The city and county TG's are in separate banks, but they are exact duplicates of each other, as far as tower CC's, etc. The only difference between the two banks is what TGs are assigned.
I am perplexed as to why this happens. When the scanner mysteriously goes deaf on a TG, it invariably generates a feed problem report, and by the time I check it, everything is working fine again.
I can sure use some help with this...I'm tired of getting the feed problem reports for a problem I have no idea how to remedy. Any ideas, suggestions, solutions, or questions are appreciated.
