Pro 96 only picking up analog
ctreptow
Hi all
I had Loudoun Ct VA programmed and working than I changed something now all I get is the analog 46.3800 channel. The Loudon info is in bank 5 and when I move though the trunk info I see all the cahnnels but when it's scanning it will only pick up the analog 46...
Any ideas what I did.
I have walked through the program steps a number of times..
ct
whooey
Gainesville, FL
Make sure you didnt lock out the Control Channel(s). Look for the *L* in the top row, this indicates a locked out channel.
loumaag
Silent Key - Aug 2014
Katy, TX
In addition to the previous post try these:
While on bank 5 press <PRG> then Press <TRUNK>.
Does it say it is in Motorola Mode? If not press <MODE> until it does and then scan on.
If it does say that, when you <MAN> step through all of the frequencies in the system do you pick up the CCh? Does it still say "M36" and "SysID: 6B1D". If the answer is no to any of these, you need to get the CCh programmed in. If it does say that, does it say "MO" in the upper right hand corner? If not press <MODE> until it does and scan on.
If any of this doesn't fix it, I have no other ideas based on your stated problem.
ctreptow
yep it's in motorola mode.. bank 5-0 on id 29 Motorola..
I did lockout the control channel.. there was an L on the 500 channel.
Thanks sooo very much..
ct
