Pro 96 problem
demaples
Florida
First I'm new at this. I have a pro 96 scanner and it worked fine till it was jammed between couch cushions and it apparently had the keypad pushed in error. It would then only scan one channel. I reset it with no avail, then initialized it now when I press scan I get a display of "all channels locked out!" and I've went through all the lock out sequences to no avail. Any advice?
Thanks in advance
Dennis
demaples
Florida
Thanks I reprogrammed but for some reason I still can't receive local Sheriff transmissions. all I am getting is the local fire and rescue and a police band 40 miles away. Would the Winn 96 program from Starsoft help?
mciupa
DB Administrator
Moderator
Which trunk system are you trying to program? The Motorola systems are Control Channel Only and a breeze to program by hand.
WIN96 would certainly make life easier, (especially if you want to text tag, otherwise your keypad will stick to the board after a while).
Welcome to RadioReference ,demaples :)
demaples
Florida
Thanks! I'm figuring it out, plus a buddy at the Sheriff department informed me they changed to 800 mghz, that was a big help and I downloaded Win96 and still getting familiar with it.
