Scanark
I have a question about my PRO 96. Whenever I receive a transmission on a P25 trunked system(9600) I listen to, at the end of the transmission the scanner reverts to MO conventional mode and stops like it's stuck on a birdie. This only started to happen in the last few weeks. I've had the scanner for about five months. Anyway, I looked in the manual and it doesn't show a birdie on this frequency, so I removed the antenna and it stopped. I've tried to locate and source of interference in my home and haven't found anything. I then tried my BCD 396 and didn't have this problem although it would stop on this frequency(866.6500) when searching. I suspect since the 396 specifies P25 when programming it doesn't look for a conventional frequency like the 96 does. The 96 works fine when receiving the P25 signal, it's just that it then reverts to MO and sounds like a birdie. It sounds like a distant signal, so it's probably not close, I don't know. Anyway, I've enjoyed my 96 and use it and my 396 each day. Has anyone else had a similar problem? Thanks to everyone, I really enjoy these forums and check them each day.
