Pro 96 Scanning Question
btrelli
Can Someone Help, Why When My Pro 96 Is Scanning It Will Stop On A Bank # And Blink Black For A Second Or Two Then Continue With Scanning.thanks Bret
kc9kfj
Are there any frequencies in that bank?The scanner will not stop scanning unless there are progammed channels or an active frequency.The blinking over the bank # just means that bank is being scanned.
scott970
I have programmed a Pro 96 to track a Motorola Smartnet 800 mhz digital system. The scanner will track all the frequencies with the exception of one, 851.3250. The channel in question does not serve as a control channel, only voice. When the scanner should be receiving voice transmissions on this frequency, it displays 862.3125 as the VC even though this frequency is not programmed. Has anyone else experienced a similar problem and was it related to rebanding issues?
may be special tables & offsets to program in what system are you talk about??
scott970
I am programming the public safety system in Albertville. Rebanding was completed last week.
N8IAA
Fortunately, GA
Only program the Contol Channels. When a Voice Channel comes up, a TG should be assocciated with it. If you have all the channels programmed in, lock out those that are not CC's. It should take care of your problem.
Larry
scott970
I have tried only programming the control channels. Four of the five on the system rotate as control channels. The problem still seems to be the 851 channel.
