Sixty
My Pro 96 is programmed with frequencies in Channels 1 through 9. When I turn on the unit it will scan Channels 2 through 9 but it hangs up on Channel 1. It will not scan 2 through 9 unless I remove Channel 1.
If I remove Channel 1 from the scan field it performs just fine, up or down.
If I hit Srch and hold the up or down arrow it will scan through Channel 1 before moving to the rest of the Channels.
On page 113 in the Owners Manual there is mention of Resetting the scanner. How do I select a test?
I do NOT want to erase the memory!
Any assistance will be appreciated.
Thank you.
Thank you.
