I changed thngs around a lot over the past day and the problem seems to have gone away. I May have had the same TG programmed into a number of different banks.
I have since gone though and now I have one bank with analog (FM) channels.
A second bank running in open mode with the local trucked towers and known TGs programmed in but locked out.
A third bank running in closed mode with the local trucked towers and all "known" TG programmed in.
Since out areas has 100s of TGs I could find no way to program all of them into a single bank (of course), So I decided to just add new TGs as I see them in the open bank. Using this setup I have found 32 TGs active over the past day or so.
I most likely will try another scheme where I program in the TGs as found in Win96 and put them in closed banks and just leave one bank in open mode to catch the TGs that wouldn't fit in the first 7 banks. But this may be overkill... just have to find the right balance.
Anyways, still not sure what was causing some of the Alpha Tags not to display and not sure what I did to make it quit doing that. I don't think I have ever programmed something so many times in a week then I have with the Pro-96 and Win96... it's all a learning experence... that's for sure.
Thanks for listening to these ranting of this near madman... if I wasn't mad before this will drive me over the edge!
Maybe I need to put in a signature:
So many TGs, so little time!
