fuzzydad1209
So I've switched from a 250-D to a pro-96. For anyone who lives on the outskirts of the Richmond Metro area (Goochland, Eastern Louisa, Caroline, etc.), I Highly recommend it for it's superior reception. My 250-D would barely get with an outdoor antenna what the 96 does with the 800 antenna.
Anyway, I'm still using the V-scanner pre-loaded stuff to monitor the Richmond TRS and it works well, but I've found that it 1)only has 9 total frequencies programmed into it and 2) I put in the VCU PD talk group and it doesn't get ANYTHING on it--whether I'm in Richmond or on the outskirts.
Can anyone help with this? Should I disregard the V-scanner stuff and just enter the separate systems, with all freqs in separate banks and monitor them that way? I'm just wondering what the best approach is because I've noticed that I get different freqs picking up from the different areas now on the smartnet--understandably, some pick up better than others.
Anyway, if any of you can help, I'd appreciate it. Thanks in advance.
-Patrick
-Patrick
