sflyersguy
- Joined
- Jan 11, 2006
- Messages
- 31
at radioshack the cd and cable to program pro-96 scanners, is the software anygood
I haven't tried the RS software, but do get the cable, and get WIN96 programming software. You can try it for 30 days free, then you have to register. It's well worth the money.sflyersguy said:at radioshack the cd and cable to program pro-96 scanners, is the software anygood
If it is the USB cable for the pro96 the only thing on the cd is the driver for the in cable serial to USB converter. Plus it contains the product manual. Software for programing is seperate, and I would suggest win96 over scancat lite.sflyersguy said:at radioshack the cd and cable to program pro-96 scanners, is the software anygood
Your description of the error you get makes no sense in context. It may make lots of sense to you, but unless we are in your head, what you provide is inadequate to answer your question.sflyersguy said:when i click on summit it says decliced.
*When I click on submit it says declined*sflyersguy said:when i click on summit it says decliced.
