In addtion to what Joe and Frank have said so far, you have changed many setting that were best left as defualt on several areas. I am returning a file to you, I edited 3 of your banks 3, 4, & 6. I took out frequencies that should not be there for TRS's (the ones that are not CC) and also fixed the Luke AFB table so it will work. I am not really familiar with what is in what area, so I didn't feel comfortable changing around your banks. Also, you have Mesa loaded as a TRS. Isn't now off the air and part of some other TRS there? In any case take a look at the way I did some of the things in those 3 banks, and also note several things on the Settings Tab. Especially the battery settings. You had zeroed those out, which is why you had that problem you mentioned several days ago. The settings I put in there are not quite the default, but I find that they work better as they give you more warning about your batteries going down, giving you more chance to change them before the radio shuts off. Anyway, review what I did and see if if make sense.
P.S. I did not include all the banks in your original file, so don't overwrite the one you sent!
