KE7TJK
I'm running my PRO-97 in my vehicle, and have been using a Larsen NMO-150 5/8 wave external antenna, with 3db gain.
I have noticed when using this antenna that the scanner seems to overload in some areas, and reception in one part of town is almost non existent, or it is very scratchy and distant sounding. All of the freqs I listen to on 150 are on repeaters atop either the surrounding hills, or on the tall buildings downtown. In this 'bad' part of town, I can switch to the rubber duckie, and instantly my reception improves to normal. I never had this problem using the same antenna on an older mobile scanner.
Today, I stopped in to the local radio shop, and picked up a Motorola NMO mount 1/4 wave, and replaced the Larsen. So far, on my side of town, it is working the same, if not a bit better than the 5/8 wave. Haven't been to the area that I have problems. I'll report on that later.
My question for you PRO 97 users is have you noticed overload on your scanner with an external antenna? If so, what have you done to mitigate the problem. I DO get some intermod with the 5/8 larsen, but not to where it covers anything up. With the new 1/4 wave, I have noticed no intermod as of yet.
I'd appreciate hearing your experiences.
