Pro 97 Charging Indicator?
ronmchandler
Memphis, TN
Is the display supposed to indicate that the batteries are charging when plugged to the power adapter? Just bought my pro-97, loaded the yellow battery tray, 4 Nmh batteries, and plugged up the RS 9v power adaptor. The screen is blank. The Pro-83 display shows "charging" under similar circumstances. Seems the GRE should do the same or similar. Can anyone answer this question?
Many thanks.... :?:
hitmeupz
Mine doesn't display anything, maybe cause I always charge it while the scanner is off. I'll double check for you later on, but I'm pretty sure it doesn't display anything at all.
c_gutta
Columbus, OH
It will not display anything
This scanner is not designed to shop charging.
It will not indicate if its charging or not.
