btritch said:
Can anyone tell me what the CTCSS and DCS tones and setting are for on the PRO 97 and what they're used for? Fire paging tones? I just got it today and I"m not sure I understand the book instructions.. Can anyone please explaing the CTCSS and DCS settings? Thanks!
Beginning on page 21 of the pdf manual:
"CTCSS (CT) mode
CTCSS mode sets the scanner to receive transmissions
using frequency modulation (FM) with Continuous Tone
Coded Squelch System (CTCSS) subaudible tone codes.
CTCSS allows multiple users to share a single radio
frequency without hearing each other’s transmissions. In
your PRO-97 scanner, the CTCSS feature can be used to
block the reception of transmissions on shared channel to
only those that use the CTCSS mode also features a Code
Search setting that allows you to instantly display and store
unknown codes into the channel memory. CTCSS tones can
sometimes be heard as a low “hum” in the background of a
voice transmission."
DCS (DC) mode
DCS mode sets the scanner to receive transmissions using
frequency modulation (FM) with Digital Coded Squelch
(DCS) subaudible data signaling. DCS is very similar to
CTCSS, except that a digital code is transmitted instead of
an audio tone. Like CTCSS, DCS allows multiple users to
share a single radio frequency without hearing each other’s
transmissions. In your PRO-97 scanner, the DCS feature
be used to block the reception of transmissions on a shared
channel to only those that use the DCS tone that you have
specifi ed. DCS mode also features a Code Search setting
that allows you to instantly display and store unknown
codes into the channel memory. DCS data can sometimes
be heard as a low “purring” sound in the background of
voice transmission. Some DCS systems transmit a special
“turn off code” at the end of each transmission. The turn
code causes a properly equipped receiver to mute before
the transmission ends, eliminating the “squelch tail” burst
noise the commonly occurs when the signal is lost."
Also see the wiki:
http://wiki.radioreference.com/index.php/Continuous_Tone-Coded_Squelch_System
http://wiki.radioreference.com/index.php/DCS
