Pro-97 Help
daveyb
Huntsville , Alabama
I have a Pro-97 that is not working right. It programs via win-97 it scans and receives. Problem is the keyboard does not work right. The only buttons that work are the scan button and the weather button . Both are on the top. Anyone this is the way I got the scanner. Any ideas on a fix anf what can be done here?
kb3isq
Shippensburg, PA
You will most likely have to open the radio and remove the keypad and clean it with alcohol. I did that to mine and it works fine now.
Sportster77
Lake Co. Ohio
Have you checked to be assure the keypad is not locked? Press and hold the light button and it should beep as it latches back and forth from locked to unlocked.
