Pro - 97 PARTS LIST
scanall
Longview Texas
Does anyone have a copy of the parts list for a Pro -97 scanner that could be posted? This would be nice to keep in my files for future reference.
KLH
Indiana
Here is an updated list printed today.
Code:
11318532 DIODE 1N4002 RECT 600V.1A SI $.29 In Stock
10539476 ANTENNA,RUBBER 15.8CM $10.99 In Stock
10570166 FILTER,CERAMIC 455KHZ $7.18 In Stock
12357562 CRYSTAL 12.75MHZ $9.49 In Stock
12357570 CRYSTAL 20.945MHZ $8.13 In Stock
12357687 CRYSTAL 12.288MHZ $11.11 In Stock
12430674 COVER BATTERY $3.29 In Stock
12430658 HOLDER ASSY BTRY RECHRG $4.69 In Stock
12430666 HOLDER ASSY BATTERY $4.49 In Stock
12418273 CLIP BELT $3.29 In Stock
12430682 KEYTOP $5.99 In Stock
10720209 JACK,ANTENNA $8.29 Not In Stock
11840063 JACK,EARPHONE $2.87 Not In Stock
12228714 JACK POWER $2.49 Not In Stock
12430690 KNOB SQUELCH $2.49 In Stock
12430708 KNOB VOLUME $2.49 In Stock
12430617 LED FY1112H-1-TR(D OR E) $2.49 In Stock
12430716 LCD $23.49 In Stock
12430724 MANUAL USERS 20-527 $4.99 In Stock
10881886 IC,NJM2904M LINEAR 8 PIN (S) $2.49 In Stock
10894061 IC,74HC4066F 14 PIN $4.84 In Stock
12106522 IC KA3361BD SO16S $5.99 In Stock
12410775 IC SMT TMP93PS44F $54.99 In Stock
12429163 POT VOLUME 50K OHM $15.89 Not In Stock SQUELCH 10K OHM
11717485 SPEAKER 8-OHM 500MW $11.89 In Stock
12430591 PCB ASSY LOGIC $81.29 In Stock
12430625 PCB ASSY RF $27.99 In Stock CONSISTS OF: PCB ASSY RF CHASSIS TOP ESCUTCHEON TOP JACK ANTENNA PM 2X4 NI OR BLK SCREW
12430633 CASE ASSY FRONT $19.29 Not In Stock NON REPAIRABLE
12430641 CASE ASSY REAR $12.69 In Stock NON REPAIRABLE
