dad8662
Can't get my PC to see my Pro-97. When I connect serial cable to scanner, it goes to CLONE mode, not PC mode. I am trying to download into WIN97. Any suggestions? Thanx
The radio works in clone mode when you're programming it. The program acts like another scanner at the end of the cable. There's no "PC" mode.dad8662 said:Can't get my PC to see my Pro-97. When I connect serial cable to scanner, it goes to CLONE mode, not PC mode. I am trying to download into WIN97. Any suggestions? Thanx
No other cards installed that would look like serial ports? Like a modem?dad8662 said:My first computer is running Windows XP, only has one COM port, but device manager shows COM1 and COM 2 working properly.
Then I'd suspect either the cable or the scanner.Motherboard manual lists only one, COM2. Just to be sure, I have tried both, no difference. When i tried COM3 XP tells you it doesn't exist. The second machine i tried it on only has one COM port and only COM1 in Device Manager. Same results.
There's no such thing, AFAIK - there are USB-to-serial adapters, but you have serial ports, so you don't need one.Maybe I should try a Serial to USB interface?
It doesn't sound as if there is a conflict - just a component that's not working.Would that end the chance of a COM port conflict?
I guess in some areas they can get away with that. Around here you'd have to tie someone up for a day or so to do that.BaLa said:well they will program it for you, only if you ask.
Also it depends on where you go.
When I originally got my Pro95 (diff scanner but still applies) the guy there read the manual and manually programmed it. :lol:
I asked him about it and said something about Franchise storeand not having a cable
