I just purchased a Pro 97 and I'm having issues with it.
First -
I'm using PSRedit300 to program this scanner. What I'm most anxious to here on this scanner is the Moline IL police and fire departments. They use an EDACS trucked system. For some reason while I'm in scan mode, the display says "Scanning up...." but I NEVER HEAR A THING!!!! If I go to "man" mode I can find the control channel and can hear it fine. I can also scroll through manually and catch the tail end of a conversation. Whats going on???
I have checked and rechecked my frequencies and LCN. I got the freqs from RR and put them in the order they were listed, starting on channel 101 (not 100) as suggested in some of the other threads I've read.
The Mode for all 10 freqs is ED and the bank mode is set to ED. I'm also scanning in the Open Mode. I have also programmed all of the TG ID from the RR site, and have them enabled. None of the freqs are locked out.
Second -
My scanner seems to like to get stuck on that trunked bank. I have Conventionl freqs programed into banks 0 and 2. I have the above mentioned trunked freqs in bank 1. If I have all 3 banks on and push scan, the scanner will scan through from bank to bank 4 - 5 times and then just stop on bank 1 (the trunked freq bank) and be stuck there. If I turn bank 1 off, the scanner seem to work normally.
Can any of you help? I'm just about at my wits end here.
Thank you in advance!!
First -
Second -
