Pro 97 Questions
Judongolfer
Palm Beach, Florida
Hello
I'm new to scanning and just purchased a used Pro 97 scanner. Do I need to purchase the software to program this scanner? So far the only thing that comes in clear is the weather band. I have not been able to program any local channels. If I can get this scanner to work I would also like to purchase a antenna that will enable me to get reception from further away cities. Can someone tell me realistically how far away in miles should an indoor scanner antenna expect to receive?
I also would like to know if there are such things as scanning clubs where I could learn more about my scanner and scanning in general? I know they have ham radio clubs but do they use scanners too?
Thank You
Ron
KC5EIB
Flower Mound, TX
Hello
No but programs like WIN97 mahe it easier to manage the frequencies in the radio
Can someone tell me realistically how far away in miles should an indoor scanner antenna expect to receive?[/
Depends on the transmiter power, antenna height, and terrain.Airplanes can be received from LONG distances due to height in air while traines are close to the ground and have a much shorter range.
You have asked the question at what could be said is the largest scanner club in the country.
Many Ham operators are also scanner users and can help with local information.
45SigSauer
Lowell, IN
As KC5EIB said, your at the ultimate site for any question you have. I use WIN-97 to program all my scanners, I have been using it for so long I don't know if I can remember how to program manually anymore. Where do you live and what do you want to monitor?
clydes
Thanks for the info on software. I also have Pro 97 w/discrim tap. I live near Alma, Ark in Ark river Valley. I pick up around 25 miles excepting mountains. Can anyone explain to a newbie like me how to program AWIN ? Thank you. KB5SVW
AWIN Is APCO25 Digital. Pro 97 will NOT do digital
Also 97 will not do 700Mhz trunking
gmclam
Fair Oaks, CA
Pro-97 ....
Hello. Welcome to RadioReference.com. Great first scanner.
I programmed my first PRO-97 by hand after figuring everything out "on paper" first. I equate it to learning to drive on a stick shift. While automatics are nice, you never know what need will arise. But I use WIN97 to do all the heavy lifting. It comes with a 30 day free trial, but I just paid on day 1.
Generally speaking Weather is the only thing programmed in it from the factory. Yeah there are 150 other channels programmed, but it is likely not a single one of them is used in your area. However, you can use the SEARCH function to find something active (instead of SCAN).
Read this thread here.
Yes there are, but it depends on where you are, and they are not the same as ham radio clubs. Regardless you'll learn more by reading articles and information from this site than you want to know. Check out the Wiki section. Start with info on your scanner and go from there.
clydes
Thanks to AlabamaRS. If a Pro97 won't get it then no sense wasting more time & money on doing the impossible. I have new Dell w/Windows 7. Sales people say Win97 is in process of getting a 64# compatible version of ARC 300. I checked at BuTel also. Thanks again. KB5SVW
Gadgetman728
outside wichita, Kansas
Windblows 7 & Starrsoft Win97
I have been programming 95's, 97's & 164's on an Acer Lappy running Win7 ultimate 32 bit, for a few months now. I've got all the updates for the cord drivers as well. I'm using Don's Win97 program. The program uploads to the scanners pretty well, but occasionally trying to download what is in the scanner already, it locks up my puter. It applied the firmware update for my 164 flawlessly.
Problems are probably due to buggy USB drivers, the puter was set up for Vista, although I've had everything but Vista on it.
I've had my PRO-97 for almost three years and have never felt the need for a software program. The Orange County (CA) TRS is only 75 frequencies and is a Motorola Hybrid system, so there's no channel sequencing that needs to be followed. It's fairly simple. And other trunked systems around here are fairly simple to program as well. It just depends where you live and how complicated your local systems are. If I had to give you any advice, I'd try programming by hand first if, for no other reason, you'll learn more about your scanner's capabilities through hands-on training.
Dave
KA6TJF
