Pro-97 reception
scannermaniac
Browns Mills N.J.
Does anyone have any advice for me as relating to the pro-97 reception for the NJSP?, I am now using a pro-97 with a 800mhz Duckie and I am still not receiving, maybe i set it up wrong, i don't know, I used win97 to program it. Any Help would be appreciated.
tglendye
Grid Square FM08LJ
While you're at it, manually scroll to your control channel and see if you can hear the data. If so, you are in range and should be able to trunk it if you're set-up correctly
