Pro 97 won't Trunk in closed mode
mkewman
Sacramento County, California
my 97 won't trunk in closed mode, in open mode i can pick up all the tgs but in closed mode it picks up nothing.
i have tgs programmed... so theres no reason it shouldn't work.
Grog
Banned
West of Charlotte NC
If you are using win97, are any/all of these unchecked? (circled in pic)
I once unchecked all of them, and it took a few minutes to figure that one out :lol:
mkewman
shizza. i may have... how would one turn those back on without using a computer? mine is at my parents house, i just moved into my apt, and so i'm only able to use a mac.
how do you do it manually?
RolnCode3
Sacramento/Bay Area, CA
Page 81&82 from the Pro-2055 manual, page 76 in the -97 manual:
turning an ID sub-bank on or off
Follow these steps to turn the ID sub-bank on or off
during the program mode:
1. Press TRUNK repeatedly to select the desired subbank.
2. Press FUNC then 1 to turn the sub-bank on if it is off
or off if it is on.
during the scan mode:
1. Press FUNC while the scanner is stopped on a voice
channel transmission.
2. Press TRUNK. The display indicates which sub-bank
is turned on or off, and the active sub-bank number
fl ashes.
3. Press FUNC and the number of the sub-bank you
desire to turn on or off. For example to turn subbank
4 on or off, press FUNC. Then press 4.
KE5BCP
Analog Man
Lewisville, Texas
Beginning at the bottom of page 26 of the pdf owner's manual:
"open and closed modes
You can set your scanner to change the way it receives
signals. These settings, called open mode and closed mode,
affect how the scanner receives signals from communications
systems that use some type of closed squelch (such as
Motorola, EDACS, and LTR systems).
In open mode, you hear all active talk groups except those
you specifi cally exclude, making it easy to hear everything
going on. In closed mode, you hear only those talk groups
you specify. This makes it easy to listen only to talk groups
you are interested in and exclude others.
When you select a system voice channel manually, any
transmission opens squelch, regardless of the current
mode.
When no ID code is programmed into the scanner, it
receives the signal in MO, ED, or LT mode. In open mode,
the scanner stops on any transmission. If the ID is stored,
the text tag appears on the display. Otherwise, the talk
group ID appears on the display. In closed mode, the
scanner only stops on a transmission if the ID is stored.
You can set each of the scanner’s channel storage banks to
open or closed mode.
In open mode, the scanner scans signals transmitted in all
systems. The scanner stops on any ID code and only uses
the ID list to look up ID text tags.
In closed mode, the scanner stops only on signals that have
an ID code which is found in the ID list for the bank. Also, the
scanner scans signals transmitted only under the following
conditions:
• When the signals are in the FM, CT, or DC mode.
• When the signals are in the MO, ED, or LT mode and the
signal’s ID code matches the programmed ID code
You can also select the user or talk groups you want the
scanner to receive in closed mode.
When you set a channel storage bank to open mode, +
appears under the bank’s number while scanning. When you
set a channel storage bank to closed mode, - appears under
the channel storage bank’s number while scanning. OPEN
or CLOSED appears while the scanner is in manual mode or
while the scanner is receiving a signal during scanning. See
“Changing the Open/Closed Mode” for more information
about setting the open and closed modes."
NWtoSFO
Citrus Heights, CA
Great help here. I recently overhauled my Pro-97 in Win97 and must have unchecked the closed mode box thinking, ". . . why, of course I want it open!" It took me 3 days of hearing everything I didn't want to hear (and hadn't programed) before I searched for answers here and came to this thread. Everythings fine now.
