ARCXT: PRO With Uniden Bearcat BCD325P2 And Capacity Plus
I am trying the higher frequency as LCN 1 and the lower one as LCN 2. A few other questions, though:
-Since Butel ARC XT PRO logs Color Code 14 as 100E, should I program it as CC14 or as 100E? I looks like I could actually leave the Color Code blank on a Cpacity Plus system, is that accurate?
-Could I program it both ways to see which works or would that adversely affect something else?
-If I set it to ID Search Mode, will that work just like any other trunked system and monitor all talkgroups, unless they are locked out?
-I am aware of four talkgroups, three regular ones and an ALL CALL. Do I need to program the ALL CALL or will it simply be received on any of the other talkgroups, if it truly is ALL CALL?
-When I read through
DigitalMobileRadioUpgrade < UnidenMan4 < TWiki it refers to Using LCN Finder for DMR Trunked Systems. I states "To use LCN finder, select MENU --> Analyze --> EDACS/LTR/DMR LCN Finder. Then, select the system and the site on that system to analyze." I select MENU, but I don't see an Analyze Mode. Does the BCD325P2 not have that? Or, can that only be selected when I am actually receiving voice traffic?
