Pro106/197 Locking up??
oilmillcharlie
Southern RI
Has anyone had a problem with their Pro106/197 locking up on UHF frequencies in the 853 range with no apparent squelch?? The radios will sometime will go silent. When I look over they are locked up on an 853 mhz frequency with no sound whatsoever. Don't no if it is an open carrier or a scanner problem.
B.K.
gewecke
Banned
Illinois
B.K.
While in the scan mode, if it locks up then disconnect the antenna and see if it resumes scanning? If not, it's likely to be a "birdie".
Mine does this in a different area.
73,
n9zas
cg
Connecticut
One of my 197's does something similar and it takes a slight movement of the squelch knob either way to resume.
Those radios are also very prone to overload, especially from FM & NOAA WX. That could very well be what you are seeing. I have a FM and WX filter on the splitter that feeds my 3 197's and it made a world of difference.
chris
rk911
Rich
Wheaton, IL
chris
can u please post a link to the filter you're using?
