Pro164 Firmware 1.04
howleyt
oxford, MI
I see some older threads about the Pro 164 firmware 1.04 update and people having trouble with it. I downloaded it tonight and when I execute it, I get a dos box flashing on the screen, then nothing. The application does not give any prompts. I tried running it under Vista and XP with similar results.
Does anyone know if the archive is still bad like previous posts say, or is there some trick to getting this to run?
Tom
jerk
jerkville
Tom
If you read the "other" posts, that informaiton is correct, Change the file end to .ZIP not .exe
and extract, then run it.
loumaag
Silent Key - Aug 2014
Katy, TX
Thread Moved
Please don't post GRE built Radio Shack scanner questions/topics in the GRE forum. The GRE forum is for GRE Branded radios only. Thanks.
howleyt
oxford, MI
Thanks, I'll give it a try.
Mod, please close this thread or move to Radio Shack Forum if you wish.
Tom
howleyt
oxford, MI
Changing .exe extension to .zip was the fix I needed. I was able to then unzip the archive and run the updater to get to 1.04. Thank you for the advice.
Tom
