Pro197 & 380-400 Mhz
TRON
Can anyone advise if the pro197 will trunktrack the 380-400mhz band that some federal agencies are using? Just got the radio yesterday and wondered if someone had been able to field-test it in this band.
Thanks a million.
jeffkraussws
Here's a portion from the Frequency Coverage specifications:
216.0025-219.9975 MHz...............(in 5 kHz steps/FM)
220.000-224.995 MHz...................(in 5 kHz steps/FM)
225.000-379.99375 MHz......... (in 6.25 kHz steps/AM)
380.000-419.9875 MHz............(in 12.5 kHz steps/FM)
420.000-450.000 MHz...................(in 5 kHz steps/FM)
450.00625-469.99375 MHz......(in 6.25 kHz steps/FM)
470.000-512.000 MHz..............(in 12.5 kHz steps/FM)
So the answer is yes, provided you set up the Trunking Tables correctly.
But I haven't field tested it.
mikey60
Oakland County Michigan
Thanks a million.
Yes, it will.
Mike
wise871
N.W. Florida
I believe TRON was asking if it would follow TG ID's on the the MIL-P25 system. Earlier versions of the RS scanners such as the PRO-96/2096 were unable to follow TG.
jeffkraussws
Are you suggesting that MIL-P25 is different from APCO25?
TRON
Rs 107 380-400 Mhz
Thanks for the help guys. You're the best!!
