pro197 &uniden 996t help
frank125
hello while doing a limit search on my pro-197 in the 865-868 range it stopped on a transmisson only showing the frequency, but at the same time doing a limit search on my uniden 996t when it stopped on a transmisson it showes motorola system with sid and the id#, i am impressed with this from uniden while the 197 is the newer scanner it does not decode this am i doing something wrong or is this how the 197 works, you would think it would decodeand show the same info as the uniden. any help as to what i have to do to show this info or does it just not do this like the uniden, also would the two gre scanners be the same way the 500&600, thanks for any help on this.
hcpholder
I think thats where the Uniden/BCs have it over the other scanner models. I use the handheld model Pro106 and it is the same way. I only see system ID information once it is stored, then looked at.
