pro197 volume squech brass pin
Dea10766
Penndel Pa
need part cant find
can anyone tell me the part number or where to find brass part for volume squelch that's in the pic I've tried every where but cant even get a part #
Dea10766
Penndel Pa
Wirelessly posted (Mozilla/5.0 (iPhone; CPU iPhone OS 7_1 like Mac OS X) AppleWebKit/537.51.2 (KHTML, like Gecko) Version/7.0 Mobile/11D167 Safari/9537.53)
I had a pic but it's a brass pin for volume and squelch
mikewazowski
Staff member
Ott and Aboot
I've merged your posts into one thread. Please do not start new threads when a reply to your existing thread will do. Thanks.
krokus
Southeastern Michigan
As ratboy pointed out, it is not just a pin, that is the shaft coming out of the control.
What has happened, that you think you need a new one?
Sent via Tapatalk
Dea10766
Penndel Pa
Brass pin broken
The brass pin broke and can't control volume I removed the pin and tried to duplicate it but it's not an easy piece to make I would like to know where I could order periometer from
Dea10766
Penndel Pa
potentiometer I know I spelled it wrong but I would like to order one it's easy to install the pin with a clip on the end
kruser
Central St Louis Cnty, MO
RG82BS-2A1-B103-0EC2
or GE-03D-0200
or GR-08D-1220
The above part numbers are from the 197 service manual. They are manufacturers numbers and there are no Radio Shack numbers listed.
I'm not sure if the numbers are GRE numbers or not but I suspect at least one of them may be a Spectrol part number. It could be a custom dual control so you may not be able to find it.
Good Luck!
