Pro2096 / RS / GRE Usb Cable Pinout
Yocuz
Gloucester County NJ
I have been searching this site with no luck. Does anyone know the pin out (ie. pin configuration) for the usb/pc cable used with Pro2096.
Without having the cable in front or me but I seem to recall a tip, ring, sleeve with the possible of another.
I can't find the information online anywhere. I am also hoping to find the RS232 command sheet for the 2096.
If anyone can help me out it would be greatly appreciated.
Yocuz
Thanks.. Going to try and make up a turnaround to a DB9 so I can monitor the output of the software (arc96, win96 etc...) on a serial capture platform to see what commands the software is spitting out.
Yocuz
Have you ever monitored the transmission of date to and from the scanner on a sniffer on your pc. Jut was curious what form the packets are in.
Blackswan73
Central Indiana
Tip-RX
Ring-TX
Sleeve-Ground
You can use a FTDI based USB to serial cable. In theory, a Prolific cable ought to work also, but Prolific doesn't play well with Windows 8
