Pro43 vs 125AT
superman2112ms
Saint Charles
Other than computer programming and that's
a big one, is there any other reason to get a Uniden 125AT if I have a pro43?
ind224
Indianapolis
I have a Pro43 and would guess the 125 has better audio (why I got my Pro97) so others can hear in a group setting.
Alpha tags are nice especially when a "guest" is listening. Display visibility especially needing a light the Pro43 is weak but surprisingly the 125 does not have backlit keys like Pro97 and that would eliminate it from my roster. The near field searching is a great feature the 43 does not have. One more beep of the Pro 97 horn: 1000 channels.
superman2112ms
Saint Charles
Those back lit keys are definitely the cats meow.
superman2112ms
Saint Charles
Well the 43 will be used to do miscellaneous air band stuff. The BC246t will be for fire ems. I have each of the x36 radios. But a lot of simulcast. Need to play with some settings. Should have also bought the SDS series last year instead of the x36hp series. Anybody want to trade a BCD436hp or BCD536hp for an SDS radio. Now I am ranting. for reasons not fully explained here.
Scan125
UK
Not dug into detail but in EU / Other territories then the civil air band is on 8.33kHz spacings/steps. So any scanner confined to 25 or 12.5kHz spacings/channels will miss out on 8.33kHz stuff.
I don't know if the US/Canada/South America are using 8.33 frequencies but you should check this.
The 125 series of scanners can generally handle 25, 12.5 and 8.33kHz usage. I have no idea if the Pro43 can do this or not?
