Pro668 Error Message after power outage
blueyezca
Lodi,CA
Had the power go out while the scanner was plugged into usb power adapter. Dilemma being my pc died & I seem to have misplaced my factory sd card. Can you recommend the easiest method to get up & scanning again? I have two different error codes. The first appeared when the power came back on & scanner was turned on:Code 3-04 000CDCCA 0003. The second is the error code it displays now: Error code 3-04 000CD5C0 0003. Thanks.
Swipesy
Northern Ohio
That is a common problem when this type scanner loses power.
Try this first. Remove all AC power. Next remove one battery and wait 10 seconds. Put battery back in and see if scanner works. If it does not boot up then most likely the card corrupted and you will have to redown load your configuration from your PC.
