Pro668
apd3190
Maryland
Anyone in AA county with a 668/800 can advise on their settings for the first system. At one time I was able to receive the AA site but I did an update and for some reason I can no longer pick up the system. If you can receive it I would like to compare my settings to yours. Thanks
baybum
Howard County
Do you have a site that does work? What I have done for Howard is take the Baltimore site, duplicate it, rename it, then replace the control channels with the Howard frequencies.
Try that for AA.
apd3190
Maryland
I mainly listen to AA County and it works great. I see a lot of posts for 668 settings but i wanted the settings for someone local that was monitoring the first system.
baybum
Howard County
If you follow my suggestion, you should be able to copy AA again. I don't have any specific settings. I set it up using the software.
ThePhotoGuy
Maryland
Try using just the control channel. I have seen improved results with it but it is a pretty "poor" radio with these Phase 2 systems. I just use Pro-668 for unitrunker since I can never seem to get good radio coverage with it to listen in.
