Pro95-97
Droid53
USA
Does anyone know if the pro95 and 97 need to be rebanded to recieve the new set-up for Brevard county???
Droid53
USA
Do you need to keep the old LCN frequencies in there also?
Thank you
DickH
Thank you
Since EDACS freqs. MUST go into specified channels, NO.
If an old freq. is in channel 1 and you put the equivalent re-banded freq. in channel 12 it won't work.
gmclam
Fair Oaks, CA
Works for EDACS, LTR and some MOT
PRo-95, PRO-97 (& PRO-93) scanners will work fine on EDACS systems. The PRO-97 will do fine on LTR systems. All of these scanners will do fine on MOT systems if all of the voice frequencies conform to 8xx.xxx5 MHz. If you've got a frequency of 8xx.xxxx0 MHz in a MOT system, voice transmission assigned to those frequencies will not be tracked.
DonS
Franktown, CO
Small addition: the "8xx.xxxx0" criteria only applies to "non-splinter" systems. Splinter systems do use such frequencies, and are handled just fine by the mentioned scanners.
gmclam
Fair Oaks, CA
BUT, a "splinter" system is NOT a "rebanded" system. Here is my chart that shows all the channels and how they line up.
So the system can be:
- standard, not rebanded
- splintered, not rebanded
- rebanded, all freqs are 8xx.xxx5 MHz (can be scanned)
- rebanded with some channels that will not be tracked by older scanners
dosboot
Laurel, MS.
I use a Pro-97 on a system with the following Freq.
854.91250 855.36250 856.26250 856.63750c 857.26250
r 854.01250 854.68750 855.61250 856.71250 857.31250c 857.71250
