holeinace
I have a pro96 and listen to Motorola Type II SmartZone Omnilink system. I have a feeling I am missing some transmissions that are on status bits. How does the pro96 deal with status bits on this kind of system.
It ignores the status bits, and will allow the audio through from the talkgroup, regardless of which status bits are set. The only status bit the PRO-96 does anything with is the Encryption bit, in which case the radio will skip that talkgroup.I have a pro96 and listen to Motorola Type II SmartZone Omnilink system. I have a feeling I am missing some transmissions that are on status bits. How does the pro96 deal with status bits on this kind of system.
So more than likely I am receiving everything (except encrypted). Thanks for clearing it up for meIt ignores the status bits, and will allow the audio through from the talkgroup, regardless of which status bits are set. The only status bit the PRO-96 does anything with is the Encryption bit, in which case the radio will skip that talkgroup.
Mike
Yep, you should be, depending on what you have programmed in, and if the bank is in open or closed mode.So more than likely I am receiving everything (except encrypted). Thanks for clearing it up for me
the bank is closed, there are some VERY active TG's that I am not interested inYep, you should be, depending on what you have programmed in, and if the bank is in open or closed mode.
Mike
Ok, with the bank closed, the only thing you might miss would be those cases were one of the talkgroups you are interested in is patched to another group that you don't have programmed in. I don't know how much that happens on the system you're monitoring, but other than that, you should be hearing everything you have programmed.the bank is closed, there are some VERY active TG's that I am not interested in
The PSR-500 does that, but I don't think the PRO-96 recognizes any of the 4 status bits.The only status bit the PRO-96 does anything with is the Encryption bit, in which case the radio will skip that talkgroup.
You may be right, I never had an encrypted 3600bps system to check that with.The PSR-500 does that, but I don't think the PRO-96 recognizes any of the 4 status bits.
After reviewing some other info I have, it appears that the PRO-96 might actually skip encrypted talk groups on Mot 3600 CC systems. (My info is related to the PRO-97, which does share some internal traits with the PRO-96. The PRO-97 does appear to check bit 3 in the 16-bit Mot talkgroup ID.)I monitor a 3600 baud Motorola Smartzone system on SAFE-T in Indiana, which has encrypted TGs on it and my 96 disregards them somehow or some way.
That sounds normal. The 2096 is ignoring the status bits, so 183 == 176 and 215 == 208.My city here (Joliet, ILL) has a Motorola TYPE11 analog system, when they use the "ALLCALL" TG183, TG215 even in the closed mode on the 2096 the call comes thru on TG176-East Dispatch and TG208-West Dispatch...
The PSR-500 won't show "PTCH" unless it has previously received a patch announcement message on the control channel for the talkgroup ID.On the GRE500 i see the ALLCALL land on TG183-TG215 now but i thought they were "patches" but the scanner with the latest firmware does not show PTCH" in the readout....
