jsanab14
Does anyone know how to manually program multiple base freq/offset/step's for a pro 96. I can only install 1 manually. Using scancat-lite+ v1.4.4 does not seem to work as it programs everything perfect but when I check the base freq/offset/step, it is always set to the defaualt after programming. I am going nuts because I can no longer hear digital systems that require the multiple base/offset/step data. Thnak you
