PRO96 V-Folders
RoninJoliet
ILL
Just got a 1.3ver PRO96, i do not have the software for this. I do not want to loose my freqy's programmed in the "work pad". Can someone tell me if this is the exact procedure for V-Folder use. Enter V-Folder programming, "SAVE" work pad to "scratch pad" or ".". Next,"LOAD" V-Folder ex:ILL-8. Now, reverse, "SAVE" V-Folder ILL-8 back to folder, then, "LOAD" "work pad back. Are these the proper terms to do this procedure. Thank You
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
You may view and edit folder 8 at this point in work pad. If you did not make any changes to folder 8, ignore saving and "LOAD" work pad back. Folder 8 remains as is in V-scanner until replaced through *SAVE*
You have a knack for the scanner already, great work.
