- Joined
- Jun 26, 2006
- Messages
- 104
What's the deal with getting a Pro96 to run on rechargeables? My search turned up discussion of "the yellow adapter," but I must have either lost mine (before ever noticing it), or never gotten one.
However, I'm not interested in recharging in the scanner. If I put the 4x AA NiMH batteries in the scanner, fully charged and with 2300 mAh capacity each, I'm lucky to get 20 minutes of runtime before the scanner shuts down on low battery. By contrast, 4x alkalines and the thing lasts a couple days, but since I use this a lot (on the go), I'd rather not go through 8-12 batteries a week.
Does this mythical yellow holder take a fifth battery for NiMH, or is it simply a normal one wired to permit charging? I suspect the problem is one of voltage -- the NiMHs are 1.2V, whereas normal alkalines are 1.5V... The net is 4.8V instead of 6V, but this hasn't been a problem in my digital cameras, etc., all of which get extraordinary battery life off the rechargeables. The Pro-96, though, dies in short order.
Re-reading the manual, it refers to using the yellow adapter for charging, but doesn't make any mention of impaired battery life. Does it simply add a trace to the 9V jack on the side, or does it physically take a 5th battery? Have other people run into the same problem?
