As the title would suggest, I've been trying, so far unsuccessfully, to get my BCD396XT working with Pro96com using the control channel output to serial. I have control channel data set to on, com port speed matched on both ends, and the active control channel programmed into a system in the scanner. Have tried both holding the scanner on the control channel, and scanning the system with all other systems turned off. For kicks, I have opened up a terminal session and can see the data being received by the computer from the scanner, and in the usual 4 character hex format. I've tried both Pro96com, and Unitrunker (which I've successfully used before with a discriminator tapped scanner). Have attempted both programs on 2 different computers both with actual serial ports, not using any usb to rs232 adapters. I am trying with a TRS I receive very well from my location, as I am only a few miles from one of the towers. Despite all of this, I can't get either program to decode on the system. The radio system is Motorola 9600 P25. Its got to be something simple that I am just missing I am sure. Sorry this was so long, just wanted to be sure I painted the best picture I could of what's going on.
Thanks for any help,
Ryan
Ryan
