Ok, will the program work with the newer x36hp scanners or will there be a verison of it to work with the new scanners ?
Thanks, a bunch
Thanks, a bunch
Thanks, a bunch
Scanners supported: Pro96Com - Control channel decoder for P25 Trunked Radio Systems
I'm not the author. The author is active on these forums. Im guessing there is no current support because the BCD436HP/BCD536HP do not [currently] provide control channel data over the PC/IF / Serial channel.
Mike
PRO96COM was written to use with GRE-manufactured scanners, not Unidens.
One wonders if Motorola quietly asked them to omit CC output data??
Regardless they are only giving people more reasons to build "homebrew" XTS's...
People go to XTS/APX radios because LSM isn't an issue and the audio quality will knock a scanner out of the water. You can't get control channel data from a radio either.
I was actually thinking about this earlier today I believe (if it's what you're talking about). The audio passes to external microphones, so you could setup a channel with the control channel as a conventional channel and modify a connector to a mono Jack instead of a speaker, and plug it in to a computer. Our better yet, get one of the adapters for surveillance ear pieces that accept plug in audio cables.And for Dynamic Site Roaming and better selectivity, among other things. I have no comment about CC data, except to note that the term "homebrew" does not mean "for use right out of the box"...
That's how I would do it anyway, without actually programing the system and trying to figure out how to pull the data from it that way.
If that's not what you're talking about, then I have no idea what a homebrew XTS is in this context.
