Trying to get decodes working here. Radio's rear port is the control connection, baud rate on scanner, in Pro96Com and in Win7 Device Manager set to 9600. C-CH Out set to "On" - "Rear" in menu, BC396XT selected as Decode Radio type. Com port set to radio connection, and scanner can be controlled successfully by FreeScan and similar software.
Tuning a 700MHz control channel in, I see the radio's Mode indicator indicating NFM and DAT - audio is muted at that point, and I'm assuming that's a function of the Data Squelch.
What else am I missing? I see no "Decode Buffer" indicator when I click 'Read data from radio'.
FWIW, I've gotten another setup with a Pro-2096 working so I'm somewhat familiar with the program.
