pro96com cc channel info
Curfew
Is there a program just like this that can be downloaded off the net which will follow regular analog type 2 systems that are conrolling P-25 CAI talkgroups. I would love to see what some of these type 2's are doing and connected to in the same format as the pro96com format ie. system info, patches, etc... John
MNRotrMedic
Central Minnesota
There are numerous programs able to give you the information that you're looking for. Unitrunker, Trunker.exe are just two examples. The disadvantage to these programs is that they require aftermarket modifications to your scanner. Improperly done these modifications can turn your expensive investment into an expensive paperweight. :(
If you have a steady hand and you're handy with electronics and a soldering iron they are supposedly pretty easy modifications to make. Depending on the model of scanner that you would like to modify the information should be readily accesible on the internet. There are folks on the forums here that have a tremendous body of knowledge regarding these programs and are very patient and helpful.
Best of luck!
